LAGHC.ChkPtUnsupType
Description
Received a checkpoint msg for an object where a particular field of that object is unsupported. Simply ignore.
Remedy
Check for versions running on the MSM. Make sure the versions are the same.
Severity
Warning
Message Text
Unknown checkpointed type %type% for object %obj%. Ignoring.
Message Parameters
Name Type
obj String
type uInt32
